got a targa sitting here, turtle would be an understatement just want to know although made by 'Targa' who produced the mobo and if upgrades are possible (cpu/ram)..
http://imageshack.us/photo/my-images/689/mobot.jpg
http://imageshack.us/photo/my-images/827/cpun.jpg
--------[ AIDA64 Extreme Edition ]--------------------------------------------------------------------------------------
Version AIDA64 v2.00.1700
Benchmark Module 2.7.391-x32
Homepage http://www.aida64.com/
Report Type Report Wizard
Computer TARGA-VISIONARY
Generator Jack
Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP RTM)
Date 2011-12-29
Time 21:48
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Mobile AMD Athlon XP, 1800 MHz (13.5 x 133) 2400+
CPU Alias Barton
CPU Stepping A2
Instruction Set x86, MMX, 3DNow!, SSE
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 512 KB (On-Die, Full-Speed)
CPU Manufacturer:
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us/products/desktop/processors
Driver Update http://www.aida64.com/driver-updates
CPU Utilization:
CPU #1 100 %
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 63-2000-009999-00101111-040201-VIA_K7$1AARK204_BIOS VER 1.26 A
Motherboard Name Uniwill N251C1
Front Side Bus Properties:
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 5:4
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
Bandwidth 2667 MB/s
Chipset Bus Properties:
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: VIA VT8367 Apollo KT333 ]
North Bridge Properties:
North Bridge VIA VT8367 Apollo KT333
Supported FSB Speeds FSB200, FSB266, FSB333
Supported Memory Types DDR-200 SDRAM, DDR-266 SDRAM, DDR-333 SDRAM
Revision 00
Package Type 552 Pin BGA
Package Size 35 mm x 35 mm
Process Technology 0.22 um
Core Voltage 2.5 V
In-Order Queue Depth 4
Memory Controller:
Bank Interleave 4-way
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 7T
Command Rate (CR) 2T
Write Recovery Time (tWR) 3T
Memory Slots:
DRAM Slot #1 256 MB (PC2700 DDR SDRAM)
DRAM Slot #2 256 MB (PC2700 DDR SDRAM)
AGP Controller:
AGP Version 2.00
AGP Status Enabled
AGP Device ATI Mobility Radeon 9000 (Uniwill)
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x, 4x
Current AGP Speed 4x
Fast-Write Not Supported
Side Band Addressing Supported, Enabled
Chipset Manufacturer:
Company Name VIA Technologies, Inc.
Product Information http://www.via.com.tw/en/products/chipsets
Driver Download http://www.via.com.tw/en/support/drivers.jsp
BIOS Upgrades http://www.aida64.com/bios-updates
[ South Bridge: VIA VT8235 ]
South Bridge Properties:
South Bridge VIA VT8235
Revision 00
Package Type 487 Pin BGA
Package Size 27 mm x 27 mm
Core Voltage 2.5 V
AC'97 Audio Controller:
Audio Controller Type VIA 8233/8235/8237/8251
Codec Name Realtek C200(P)/ALC201(A)
Codec ID 414C4710h
S/PDIF Output Supported
MC'97 Modem Controller:
Modem Controller Type VIA 686A/686B/8231/8233/8235/8237/8251
Codec ID 414C4710h
apologies for taking you down memory lane again
