Disable The CrawlStartPages scheduled task, thnis is set to run when the system is Idle, it has been running on my system even thouh I have indexing disabled!
The CrawlStartPages task is part of Windows Search. The CrawlStartPages task determines whether any locations that are not notification based must be indexed. For example, the CrawlStartPages task runs if you add a universal serial bus (USB) flash drive to the index by using the Indexing Options item in Control Panel. The task runs when you add the USB flash drive if the USB flash drive uses
