whats it to be used for?Pulse said:Need a complete base unit, keyboard, mouse and monitor for £500
i know its tight, but i just need the best money can buy. keyboard and mouse dont need to be anything fancy, its the tower and monitor im more worried about.
spec away![]()
that is one small budget specially for monitor aswell.thefishdude said:bst i can dothat is one small budget specially for monitor aswell.
OcUK Digimate L1931W 19" Widescreen LCD Monitor - Black £
(£126.89)
Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) - OEM
(£19.96)
OcUK 1GB (2x512MB) PC2-6400 800MHz DDR2 Dual Channel Kit
(£75.19)
Sapphire X1650 XT 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
(£93.99)
Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU
(£70.49)
AMD Athlon 64 3800+ 2.4GHz (Socket AM2) - Retail
(£74.01)
MSI K9N Neo-F nForce 550 (Socket AM2) PCI-Express DDR2 Motherboard
(£52.86)
Seagate Barracuda 7200.9 160GB ST3160811AS SATA-II 8MB Cache - OEM
(£41.11)
Shipping : £10.95
Vat : £84.50
Total : £567.37
I wasnt sure either till i read it.thefishdude said:the x1650 isnt that good no but this is the x1650xt wich is a lot betteri belive i woudl say maybe its slightly slower then the 7600 maybe but also about a £10 less.
as for the case top idea i dint realise the artic cooling one came with a power supply cause it dint mention it in the title
i dont think he does..he would have saidthefishdude said:one thing may have forgotten and i wals forgot to spec this is the operatiung system that will add another £60 if you need copy of windows![]()
...i hope
thats nearly identical to a prebuilt i was looking at just it had a 19" screen and actually was £500semi-pro waster said:This might just about be suitable although it is still over-budget, if you could up it to around £550 then get a 7300gt with DDR3 Ram you would have a passable machine. I think that is everything included as asked and it is dual core also.
OcUK Value Hanns-G HC174D 17" LCD Monitor - Silver/Black £99.99
(£117.49) £99.99
(£117.49)
Logitech Cordless Desktop EX-110 - Retail £17.99
(£21.14) £17.99
(£21.14)
Intel Pentium 4 820 Dual Core "LGA775 Smithfield" 2.8GHz (800FSB) - Retail £59.99
(£70.49) £59.99
(£70.49)
Antec NSK4400 Mini Tower Case - 380W SmartPower PSU £42.99
(£50.51) £42.99
(£50.51)
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB) (VS1GBKIT667D2) ( £71.99
(£84.59) £71.99
(£84.59)
Western Digital Caviar Special Edition 200GB 2000JS SATA-II 8MB Cache - OEM £42.99
(£50.51) £42.99
(£50.51)
NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £16.99
(£19.96) £16.99
(£19.96)
Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard £43.99
(£51.69) £43.99
(£51.69)
BFG GeForce 7300 GT OC 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £48.99
(£57.56) £48.99
(£57.56)
Sub Total : £445.91
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £12.95
Vat : £80.30
Total : £539.16
Pulse said:thats nearly identical to a prebuilt i was looking at just it had a 19" screen and actually was £500
its shocking either way.
thefishdude said:http://www.overclockers.co.uk/showproduct.php?prodid=GX-019-BG forgetthe 1650xt i mentioned this is now on special so is better and cheaper![]()
