Another Powershell AD question
8 Mar 2005
London, UK
I've been trying to export a list of members from AD groups which match a certain condition EG. *ABC* in the AD group name and I've been struggling to find the correct sequence of piped commands to accomplish this.
I've ended up trying to use the Quest addons, but am still having no luck with the format.
I require the data to be in CSV format similar to;
Groupname,Groupnamedescription,logonname,...
Code:
Add-PSSnapin Quest.ActiveRoles.ADManagement
$Groups = Get-QADGroup *ABC*
foreach ($Group in $Groups) {
$Group | out-file .\Groups.txt -Append
Get-QADGroupMember $Group  | out-file .\Groups.txt -Append
This outputs the detail I need but not in the correct format. Substituting out-file with Export-CSV merely exports a group list and throws out a few errors when the script runs.
Any help/pointers, much appreciated.
Cheers, Paul.
Hmm thanks Woogie;however the above outputs similarly to the first script in the OG and then seemingly it repeats the same logon name 3 times.
AD_GroupNAME
Logonname1
Logonname1
Logonname1
As opposed to the desired output format as;
AD_GroupNAME,Logonname1, Fullname...
AD_GroupNAME,Logonname2, Fullname...
AD_GroupNAME,Logonname3, Fullname...
AD_GroupNAME2,Logonname4, Fullname...
AD_GroupNAME2,Logonname5, Fullname...
AD_GroupNAME3,Logonname6, Fullname...
hmm, perhaps I've missed something here.
EDIT -Actually it appears the above script consolidates members to groups so it actually outputs;
AD_GroupNAME, AD_GroupNAME2, ...
Logonname1
Logonname1
Logonname1
Hmm strange;
Cheers, Paul
Hmmm, I posted the wrong code but shut my pc down since then... Ill see if I can dig it out again later.
In the format you want I am struggling to get the description in there as well due to the way you select that object and me being fairly new to powershell but to get you started the following should help (I really did give you the wrong code on Friday)
Code:
#Variables
$Groups = Get-ADGroup -filter {name -like "GROUPNAME"}
$ADGroupMembers = @()
$ADFileBuild =@()
$FileOut = @()
 FOREACH($Group IN $Groups)
    $ADGroupMembers = Get-ADGroupMember $Group
    FOREACH($Member IN $ADGroupMembers)
        $ADFilebuild += $Group.NAME+ " " + $Member.SamAccountName + $Member.NAME
$FileOut = $ADFileBuild
$FileOut |Out-file c:\Groups.csv
That will give you the desired format of
Woogies way is a good way of doing it, I just made two small tweaks to add in group description too
Code:
#Variables
$Groups = Get-ADGroup -filter {name -like "*GroupName*"} -properties description
$ADFileBuild =@()
$FileOut = @()
        $ADFilebuild += $Group.NAME+ " " + $Group.Description + $Member.SamAccountName + $Member.NAME
$FileOut | out-file c:\groups.csv
