another problem
3 Jan 2009
bristol england
right ill get oto the point
im getting blue screens but i cant figure out why
my spec is:
amd5000+be oc to 3.1
2gb ddr2 ram
260gtx
650watt psu
first of all after a while of doing intenrte opr somethign it would blue screen
now though it is happneing more often andwhen i wa splayin cod4 eveyrhting went red and black
but i have been runnign rivatuner and pc probe and niether seem that high so it isnt overheating as my cpu doesnt go above 50 and gpu doesnt go above 70
i dno what it could be cna someone tell me?
check the error log to see if there are any listings as to why you are getting the crashes? this might help point us in the right direction
the only thing in error was this
Error code 10000050, parameter1 bfd906ac, parameter2 00000000, parameter3 8052d9fb, parameter4 00000002.
after a bit of googling it sems like it should be a memory problem but i checked it and it is fine :S
What did you check it with, because sometimes memtest doesnt pick everything up, have you tried the vista memory checker on the disk?
Hawker
sorry for taking so long to get back to you
but i used memtest and am using xp atm
also tried checking hard drives with the windows hard drive error checker and it cant finish it says it failing to finfish the second bit
