Another Prodigy Build!
29 Sep 2004
Wilt of the Shire
After reading about the case in this months Custom PC and reading some threads here on OCUK about it I'm thinking about going down this route to replace my massive Raven RV03 case setup I currently have.
I have the following which I'd like to keep if possible (feel free to tell me if it will fit inside the case or not):
i7 2600k
8 GB low profile corsair ram
Gigabyte Windforce GTX 670
LG Blu-ray ODD
2 x SSD (256 & 120 GB)
Corsair TX750 PSU (non modular)
To go with this I'm thinking:
Asrock Z77E-ITX
Bitfenix Prodigy
Antec Kuhler H20 620
Sythe Typhoon Fans x 2 for Kuhler
I currently have my cpu running at 4.5 which is what I'd want to have it running at in the new build. I know the psu might be a bit tight but keeping it would save me some dosh. Do I need any more fans in the case as well? Thanks and I now wait for some knowledgeable people to come along and help me ;)
Only advice i can offer here is that you may struggle to get back to 4.5Ghz on this board, i had mine stable at 4.8 on a maximus v gene but could only get to 4.4Ghz on this board without blue screening or pushing the Vcore further than i would like.
I hear the p8z77-i from asus is better for OCing but thats another £30 ish for a couple of hundred Mhz.
