So i just got my PS3 yesterday and bought it mainly for Blu-Ray and upscaling my SD DVD's. Anyway, i set all the settings in the 'Display Settings' part to what i believe is correct using the HDMI cable:
Video output settings: 1080p
cross colour reduction filter is set to on
RGB full range (HDMI) : Full
YPB/CB PR/CR superwhite hdmi : Off
I also set the DVD Upscaler to "Full" too (i tried Normal but didn't notice any difference, Double Scale stretches it too much).
I put in Mission Impossible III and watched a scene from it to see the difference. However, i didn't really notice any. I brought up the AV Settings and turned 'Upscaling' to OFF (im guessing that just lets to the TV upscale) and the picture just looked the same basically.
Is there something i've done wrong? I noticed in the Display Settings that 576i/p (can't remember its one of those) is greyed out and cant be deselected. Is this a problem? Also, i just selected 1080p as the resolution to use and not 720p or 1080i in the Display Settings.
The TV im using is the Samsung LE40M86BD.
Thanks
Thanks
