Hey folks,
Very new to overclocking but I have read the sticky's and done some research so thought I would give it a try.
Here is some of my spec:
CPU: Q6600
MOBO: Asus Striker Extreme (BIOS 1901)
RAM: OCZ PC2-8500 (2x2gb)
PSU: Jeantech 700w
I thought I would start easy and change the FSB. There are options for how the CPU and RAM FSB's are linked in my bios, options as follow: AUTO, Linked or unlinked.
I selected unlinked, set the CPU FSB to 1250 and left the RAM as 1066(stock). I then saved my configuration and rebooted the computer back into the bios, now the CPU clock speed showed 2.7Ghz which I was happy with.
At this setting, on boot the motherboard posts but I get a message "System configuration has failed, press F1 to continue or del to enter setup) If I continue and load windows the PC seems to run fine, this includes running a small test with Prime95 (2 hours) but I continue to get the error message on start up everytime.
Also when the PC is running CPU-Z, realtemp etc dont show the clock speed as 2.7ghz only the stock speed.
If you need any further info or detail let me know.
Any help is appreciated,
Cheers
G
CPU: Q6600
PSU: Jeantech 700w
Cheers
G
, so once I start benchmarking the actual VID goes down to 1.37ish. OCCT is a good program to see this in as it outputs graphs which plot all your voltages during a test. There's no way mine would go anywhere near 3.6 at stock (1.285 from memory). But at 1.46 it is stable as you like.
