Ok guys, I have my Q6600 running at 3.6 ghz and my 5870 at 950/1300 and the Dirt 2 Bench with everything maxed out (including 8xAA) at 1920x1080 I get an average of 65fps, which is pretty good IMO. However I see plenty of benchmarks online hitting 78 with a similarly clocked 5870, and a similarly clocked i7.
Now I was under the impression that at 1920x1080 and higher (especially with high levels of AA as well) you're a lot more GPU bound, and that I shouldn't be seeing as much difference in frame rates between my CPU and an i7.
I don't have any more benchmarks at the moment to compare, but I'm definitely not seeing similar performance to a lot of benchmarks out there on high image quality settings.
Should I be seeing this amount of difference in performance between my CPU and an i7 setup when running 1920x1080 and 4/8x AA?
