Another Question... Another Thread... Memory...
5 Sep 2011
Nottingham, UK
Memory Question
I have 4 dimms on my asrock m3n78d mobo and have 2 x 2gb ddr3 1333mhz memory.
I am currently bidding on another 2gb stick to go along side my 4gb at the moment.
I am running dual channel of course at the moment, but when I add in the other 2gb it will run single channel for a while with 6gb installed.
Even with 6gb memory (3 x 2gb) will I suffer because of single channel??? as it is not dual channel with 3 of the 4 dimms with installed memory???
This is mainly for BF3!
Thanks
Cinderz
I don't think there's one answer.
Maybe it'll all run in single channel mode or maybe you'll end up with a pair in dual channel mode and 1 stick in single channel mode.
Either way then technically performance will be lower.
You probably won't actually notice the difference but if you ran some benchmarks you'd see it.
I assume you're expecting to buy this really cheaply as you can buy another 2x2GB for less than £20.
indeed, but like me, he is also skint lol (don't get paid enough from work :P )
it will do me until i can afford another 2gb stick... but i will need that really slim line memory as my cooler obstructs one of my dimms.
