Another quick speccy checkie
18 Oct 2002
Kent, UK
I'm still trying to check 100% whether the Tuniq Tower fits into my case, however assuming it does could the collective wisdom of these fine forums please cast their eye over the remaining spec?
The eagle-eyed will notice that there's no PSU, as I'm intending to reuse my OCZ-520W modular jobbie.
Any thoughts...?
Thanks. :)
All looks fine but you could save £20 by changing the E4500 to an E2200 and clock it up to if not even past the top clocking speeds for the E4500. On the downside you'd lose a meg of cache, but whether you feel you need that or not is up to you
Yeah - I did consider going for a 2200 instead, but for £20 I think I'll go for the extra cache. I'm not going to thrash the overclock on the CPU anyway - I'll probably be happy with 3 to 3.2 Ghz which both chips should be fine with.
