A close friend has asked me to build him a small ‘general purpose’ PC, in as small a case as possible. We were originally looking at Intel NUC’s but have decided that are a bit too ‘proprietary’ as well as being quite limited in expansion options and component choices, so are now looking at a slightly larger case, (no more than 20cm x 20 cm) using an Intel powered mini ITX motherboard. He would also like an internal optical drive, and the operating system will be Linux (probably Mint 16 Cinnamon) rather than Windows!
I have currently come up with the following spec:
Case: Streacom ST-F1CS EVO Aluminium Case – Silver (preferred choice)
Motherboard: Asus 81I-PLUS – mini ITX
CPU: Intel Core i3-4130 3.40GHz OR Intel i3 4330T 3.0GHz 35W
CPU Cooler: Silverstone NT07-115X (low profile as only 34mm clearance available & I don’t like push pins!)
Memory: 8GB (2 x 4GB) Kingston HyperX DDR3 1600MHz or similar, such as Corsair Vengeance Low Profile
Hard drive: Samsung 840 EVO 250GB SSD OR Crucial M500 SSD - 2.5” 240GB
Optical drive: LiteOn DL-8ATSH Slim SLOT Black 8x slim drive – or similar
Adapter cable: Serial ATA Power Adapter Cable (Single)
Power Supply: picoPSU 160w with AC/DC adapter block
Case Fan: Scythe Mini Kaze, (40mm x 10mm) – or similar quiet fan
Although I am sure that some folk will consider the choice of CPU (and possibly other components also) to be a bit excessive, this system will hopefully be in use for quite a few years, so we are looking for a bit of built in ‘future-proofing’ here. Hence the choices of the lower power Haswell range. Fortunately budget is not too much of an issue, although we don’t obviously want to go too much OTT!
All thoughts, opinions and comments are welcome, but I will again stress that this is not intended to be a gaming system, but more of a reliable, but compact ‘work-horse… and of course a quality product!
In conclusion I would add that I have also posted an almost identical post an another Forum, but I am sure that I will receive the best advice from you guys (and girls!) here on OcUK!
