Another spec help thread....
4 Nov 2002
Harlow
I currently have an Athlon XP and have decided it's time to move on, however, I am a little unsure as to what direction to take.
First of all I need to decide between AMD or intel, I am edging towards Intel Dual Core at the moment.....
Basically, I have about £400-£500 to spend and am going to need CPU, RAM, M/b & GFX card (current one is AGP). I can use my current kit for anything else.
Any suggestions as to what would be a good spec? I do play a lot of games so the gfx card is always going to be important.....
Given the budget I think this is what I would be aiming for, it should overclock nicely although you may want to buy a better CPU cooler if taking it much beyond stock speeds :)
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
£89.95 £89.95
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£94.95 £94.95
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£126.95 £126.95
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£115.95 £115.95
Subtotal £427.80
VAT £74.87
Total £502.67
£89.95 £89.95
£94.95 £94.95
£126.95 £126.95
£115.95 £115.95
Subtotal £427.80
VAT £74.87
Total £502.67
As it happens that is pretty much what I was looking at. What would be good fan wise (I intend to overclock, if not straight away, at some point). I have heard good things about a cooled called the Ninja....
