- 21 Sep 2006
...so I'll apologise in advance
I fancy changing case and could do with a few suggestions.
Current setup is in a Lian-Li A05NB, with the replacement top and a 140mm in there. Spec is i7 [email protected] w/H70 push/pull, 16GB, EVGA 570, 2x3.5 drives, and 2x2.5 SSDs.
I'm looking to keep something with a small-ish footprint, at least from depth - ideally staying around 500mm, maybe absolute max of 510mm. Height not too much of a problem. Ideally something with a side window. Need both excellent cooling performance (or potential - don't mind swapping all fans out), and ease of cable tidying.
So not much then
Any suggestions?
I've looked at the CM690II, but depth is too much I think. Looked at a few others but nothing really ticking all boxes yet.
Also looked at the Lian-Li P50B (cabling looked potentially poor), or the Lancool K62R (a possibility).
So not much then
Any suggestions?I've looked at the CM690II, but depth is too much I think. Looked at a few others but nothing really ticking all boxes yet.
