ANOTHER SPEC!
21 Jul 2006
South Wales
Intel Core 2 Duo E6600 Socket 775 2.4GHz
BFG GeForce 8800GTS OC 640MB HDCP Enabled Dual DVI PCI Express (550MHz Core Clock) (1600MHz Memory Clock) (1300MHz Shader Clock)
Antec Nine Hundred/Ultimate Gamer Case no PSU
Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard
NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter (Beige)
Corsair 2GB DDR2 XMS2 DHX PC2-6400C4DHX TwinX (2x1GB)
Hitachi Deskstar T7K500 NCQ 320GB SATA-II 16MB Cache
Sound Blaster Audigy SE/7.1 surround sound with EAX support , PCI sound card - Bulk pack
Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU
Netgear RP614 DSL Broadband Router + 4 port 10/100 Switch. Platinum Range.
Asus VW192S 19" Widescreen LCD Monitor - Black
Creative Inspire T6100 5.1 Speakers
Logitech G15 Gaming Keyboard for PC/PS2/XBOX USB
Logitech G5 Gaming-Grade Laser Mouse - Retail // This is special offer, after 29th this will change to - MX518 (Logitech)
This is the rig my friend wants, I just need some feedback.... as i have to build it i wanna make sure there's nothing in there that will cause trouble....
Wouldn't it be better and go for the E6750 instead of the E6600.. the E6750 is faster and £20 cheaper then the E6600.. thats what I would do anyway.. ;) and I agree with thefishdude.. the Corsair 520W would be better..
Cheers
Tom
