another strange error
30 Jan 2014
still having trouble with my new gfx card, r9 280x. does anyone know how to fix this error??? i have 8gb system ram
there is nothing at all, a search on google says its a common intel problem from using the intel hd gfx then getting a card but i cant actually find a way to sort the problem
heres spme pics of whats running in background
I'm sorry - but can you post sensibly?
You do NOT need a new post for every picture you post. Nor do you need a new thread for every single issue you have with your GPU. One is sufficient.
my apologies for that however i just thought given that these are dif problems at dif times then a thread for each one was appropriate
Ive had the same problem, though Im running an 8350 and a 290x. Have you got a samsung evo ssd? I first had my problems when I put mine into maximum capacity which reduced the size of my page file
no my ssd is a mushkin, also i have just whacked an extra 8gb into my pc ( borrowed from a friend ) and i still get the same error.
did u manage to fix your problem? this has only started recently
Low memory warnings happen when Windows has run out of space to put the data it needs to store when you’re running different applications. This can be either in the RAM modules in your computer, or also on the hard disk, when the free RAM has been filled up.
Typically if you’re getting these warnings, something has gone wrong with the paging file that uses your hard disk for extra storage.
You can check this by opening the Performance tab of Windows Task Manager (press the Ctrl-Alt-Del keys simultaneously).
taskman3
The page file is almost full – not good!
If your page file usage is almost full, and the Free memory is low, then Windows is running out of memory for your running applications.
This can cause things like web browser crashes, other program crashes etc.
How to fix it
» First, check that you have enough free disk space.You can usually do this by clicking on Computer from the Start Menu, and then looking at the free space value to the right of Local Disk.
If this is lower than a few hundred MB, then you need to free up space on the disk by deleting files, and then emptying the recycle bin. This will free up disk space for the paging file to use.
» Your page file may be switched to manual instead of automatic control, and set to too low a value.
Check this by right-clicking on Computer and selecting Properties
» Click on “Advanced system settings”, then the Settings tab under Performance at the top.
» The “Performance options” page will open. Click on the “Advanced” tab.
» Now click on the “Change” button under “Virtual memory”.
» You will see the Virtual Memory options page. This controls the size of the paging file.
Usually you can tick the top checkbox for “Automatically manage paging size..” and Windows will handle everything itself, as long as you have enough free disk space.
However, you can keep this checked off if you have reasonable values set here.
What are reasonable values here?
See below..
Paging File – Manual settings
Most of the time, you won’t need to use manual settings for virtual memory. However, there are some outlying cases where it might be useful.
One of these might be where you have a limited amount of disk space, and don’t want the available free space to be increasing and decreasing all the time as Windows adjusts the size of the paging file.
Considerations when modifing virtual memory settings:
» Unless you have a lot of memory (at least 8GB) and are using a 64-bit version of Windows, then you should have at least one disk set to use a paging file. This will typically be the C: drive.
» You don’t necessarily need to set a paging file on more than one disk, although it’s possible.
» Recommended minimum size is 512MB for compatibility reasons.
» The Maximum size is a matter of preference, and depends on how many applications you run at the same time, but it’s probably better to set it to at least 4096MB (4 Gig) or higher.
» Using both a SSD and standard hard drive in the same computer?
Moving the paging file to the SSD disk can greatly speed up your system, since page file access can be one of the most frequent reasons for read and write usage of the disk.
This is especially true if you don’t have that much physical RAM installed, or your disk light is frequently lighting up due to disk page file swapping.
There was some concern with earlier SSDs that putting such a highly-used file on the SSD would lead to a shorter lifespan for the solid-state disk, however this is unlikely to be a concern for newer SSDs and the performance boost could be significant
Has it worked?
Once you’ve either freed up disk space or adjusted your page file settings, you can start the Task Manager again to see what’s happening.
Note that you might have to reboot your computer before doing this if you have changed the virtual memory settings.
Try to start using something that uses up memory, such as a web browser session with a lot of open tabs. If it appears that your page file space is not being exhausted, and you don’t get any popup error messages, then the problem is solved.
To prevent low-memory problems reoccurring, make sure to try to free up enough space on your disk if it’s running low.
Found this Robert, maybe worth a read. Hope it helps.
Also found this below to do with memory leaks with new drivers. Worth reading.
'Download Poolmon and you'll find what's leaking.
My guess is the GPU driver, i had that problem it was spilling out 2.7 GB of ram, doing absolutely nothing just staring at my desktop.
So i uninstalled the driver, installed an older version and BAM memory usage was normal again.
Have the same issue, I Upgraded to a Radeon 7990 a couple of days ago and am only experiencing this problem since I have. I thought that installing the latest drivers might help but it doesn't.
Been experimenting on it a few times, happens within 1-2 mins of joining a game (includes single player)'
If you have Win8
Go into taskmanager, performance tab, on the bottom you should see resource monitor, new window opens press "Memory" tab.
Then align the "Working set" to see which process uses the most memory.
One more thing you should check.
Go into Taskmanager, performance tab and tell us how much MB or GB the "non-paged pool" uses.
Anything over 1 gb is a huge memory leak. Mines currently 45 mb.
Cheers. :)
