another system check please
5 Nov 2005
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£109.95 £109.95
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£107.95 £107.95
MB-003-AK Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard (MB-003-AK)
£53.95 £53.95
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£126.95 £126.95
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.95 £14.95
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE)
£52.55 £52.55
CA-000-TG Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU (CA-000-TG)
£50.50 £50.50
Subtotal £516.80
VAT £90.44
Total £607.24
I have a nexus 3500 psu from my oldish machine, will it be ok, or should i get the tagan?
thanks
Go for the Tagan or some other quality-spec PSU like Seasonic, FSP, Enermax, etc.
It's a good spec. If you can afford a little more you might consider switching the mobo to one that is a better clocker like the DS3.
