- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
We pride ourselves on providing the best, latest and greatest hardware.
And we have done it again! The new Scout II from CM Storm is available ONLY AT OCUK!
CM Storm Scout II Midi Tower Gaming Case - Black @ £83.99 inc VAT
CM Storm Scout 2 - The long awaited successor to the infamous Scout is ready to be deployed! The Scout 2 follows a more round futuristic theme and features improved steel reinforced carrying handles, bolted to the core structure. The front console has been upgraded to USB 3.0 for high power charging and lightning fast file transfers, and can be hidden and protected from dusty battlefields, friendly fire and melee attacks behind a slide cover. The 1st HDD cage can now be removed, to support monster VGAs like the NVIDIA GTX 690 and AMD HD 7990, turning it into a powerful Battlestation.
- Materials: Polymer, Coated Steel Mesh and Body
- Dimensions (W x H x D): 230 x 513 x 517.5mm / 9.1 x 20.2 x 20.5 inch
- Net Weight: 8.3 kg / 18.3 lbs
- Motherboard Type: Micro-ATX, ATX
- 5.25" Drive Bays: 3 (exposed)
- 3.5" Drive Bays: 7 (hidden)
- 2.5" Drive Bays: 2 (converted from one 3.5" drive bay)
- I/O Panel: USB 3.0 x 2 (int.), USB 2.0 x 2, Mic x 1, Audio x 1 (supports AC97 / HD Audio)
- Expansion Slots: 7
- Top Cooling: 120mm fan x 2 (optional)
- Front Cooling: 120mm fan x 2 or 140mm fan x 1 (optional)
- Rear Cooling: 120mm red LED fan x 1 (with LED on/off function)
- Bottom Cooling: 120mm fan x 1 (optional)
- Side Cooling: 120mm fan x 2 (optional)
- HDD cage Cooling: 120mm fan x 1 (optional)
- Power Supply Type: PS2
- Maximum Compatibility: VGA card length: 287mm / 11.3 inch (with HDD cage); 399mm / 15.7 inch (without HDD cage)
- CPU cooler height: 147mm / 5.8 inch (with side fan); 162mm / 6.4 inch (without side fan)
Only £83.99 inc VAT.
ORDER NOW
ORDER NOW
