another vista problem (suprised?)
14 Nov 2005
Belfast
ok im begining to think vista wasnt such a good idea :(
i cannot get my netgear wg311t working at all
vista doesnt recognise it
i have 64 bit home premium and i have installed the latest drivers and ther is 64 bit beta drivers but ONLY the drives no utility to install them with and i have no idea where to put THEM
the netgear programme runs but it wont actually open i can see it running in the task manager. so can some1 plz tell me what to do with these drivers and how to get it working :)
thnx
If you open device manger, there should be the network card with the ! symbol next to it, if you right click, update driver, then point it to the folder that you have downloaded, it should work then.
