Another watercooled CM690ii
4 Apr 2003
Manchester
After much deliberation in this thread I have ended up here
Final parts list
i5 2500k
gigabyte p67-ud4
4 gb corsair xms3
ati 6950
ocd vertex 2e 60b ssd
500gb old hdd
coolermaster 690ii advanced
corsair tx750w psu
laing dcc-1t 18w pump
xspc dual bay ddc res
xspc delta v3 cpu block
zalman fan controller
tubing, clips, anti kink coils etc
HW labs black ice SR1 240 rad
24" iiyama LCD 1080p
keyboard + mouse
Just a note for anyone contemplating a bottom rad in this case. It's a tight fit as you can see. I ended up choosing the rad especially for it's reduced lenght over the other fat 240mm rads and then measuring up for the PSU
Yeah, I just noticed that. Looks like something small tried to eat it.
It was an old fan that I had to superglue something to. Will probably replace it at some point.
I didn't neet the coils for all of it but the further back rad connection did and I didn't want some done and some not
Yes thats the plan. Just run out of cash at the moment. Next steps are a gpu block, rs240 for the top and some braided.extensions for the 24 pin, pcie's and 12v (black of course)
Why not stealth the GPU to make it all black, then buy the Bitfenix Alchemy extensions in Orange to match the PSU? Would look awesome in my opinion!
Actually just went back to check the tems again now that the IC9 has had time to settle and the cores are 55-60 deg under load from prime. The same overclock was 72-78 or air using a thermalright archon and 1 fan
