Hello, so the time to replace my HD6950 2gb has finally come ( I was suppose to do this a while ago) and im stuck on what card to get.
My current picks are either 7950/7970 or a 670 with about £300 to spend.
If I choose the 7950/7970 this means I may go ahead with getting a 1440p display as I like the sound of the extra gig of ram and higher memory bandwidth that comes with the amd cards.
If I go with the 670 it means I will go ahead with a 120hz display for 3d gaming and 100+fps gaming plus physx.
I will more than likely be looking to crossfire/sli in the future.
Thats the way looking at it at the moment, either card could decide on what display i'll replace my current 1080 display with (currently using a cheap 22'' lcd
Thanks
)Thanks
(also cheapest non ref)
