).no good going with 02 as they are owned by BE so it will be the same network i thinkBeen with O2 up to 24Mb on their LLU for over a year now. I used to be on AOL 8Mb and the difference is like night and day.
No complaints about O2 so far apart from a couple of outages that affected the entire network, other than that, spot on and I would recommend them ( or *Be - depends whether you are an avid online gamer or not).
yes i im,its defo not my end ive changed everthing including a new router never had probs with other isp so im moving on for sure after paying off my 5 months remaining,gutted VM fibre optic isnt in my area.Yeah it will, sorry - my fault, I didn't read your post properly!.
Are you on an LLU enabled exchange with Be then?.
