- 19 Apr 2004
- London
I've had a busy weekend trying to upgrade 2 systems and it's all gone rather wrong.
I wanted to swap 2 cpu's over, swap a graphics card around and install some more RAM, but i've run into a problem in that my desktop PC isn't posting.
The only thing that's changed in the machine is the CPU, RAM, cooler and graphics card. I've also moved it to a new case. I've tried using the old CPU, the old RAM, the old graphics card and nothing is making it do anything. To make matters worse the case doesn't have a speaker, I did try connecting one from another case but it didn't make a single noise.
All the components seem to work fine in another PC too.
Any ideas what could be wrong? I tried re-seating the motherboard and wondered whether that could have been the issue - there was a problem with one of the screws and it had worn off part of the metal when i had screwed it in and a bit that looked like copper from the board was exposed - would this cause a problem, and if so, what can i do to fix it?
