Hi,
please, can I ask for a bit of help with motherboard recommendations and advice for an upcoming 9800x3d build?
I presently have a 5800x3d build, so some parts like psu (Corsair RM850X), gpu (4080), cpu cooler (Peerless Assassin 120), case (lancool 2) and m.2 drives will just be transferred over.
Also, I have the 9800x3d cpu and some Corsair 32gb 6000 cas 30 memory that I have already bought and received to fit into the new build.
I'm not wanting to overclock, and I am looking for an easy to set-up (including easy bios) and stable board with at least 3 m.2 slots, pcie 5.0 gpu slot, really good audio. Wifi is not important.
My thoughts so far are - MSI X670e Gaming Plus Wifi, MSI X670e Tomahawk Wifi, Asrock X870e Nova wifi (though this one looks a bit complicated for me).
The budget I have is about £350 though less spent is better. I have not had good experience with Asus boards, but my present MSI X570 tomohawk has been excellent, plus it has a relatively easy bios.
I used to enjoy pc building but now the whole idea of doing a bios update to enable the motherboard to see the 9800x3d, taking apart my present build and building a new one(not got much space in my small flat), setting up bios and of course re-installing Windows just gives me a nervous headache.
I'd appreciate peoples experiences, advice and recommendations on the best motherboard to choose (also compatible with the Corsair memory that i've bought).
Thanks in advance.
Thanks in advance.
