Another "which pre-built" question
2 Aug 2010
Sussex
Right, so I am comparing the pre-built systems on OCUK and cannot decide between 3 and was hoping for advice. The system will be used for gaming at 1920x1080 resolution with some time multitasking simple things. Ideally I am looking to add in another 480gtx in about 6months to a year when their price drops.
Here are the 3 systems:
- Case: Antec 902 Gaming case with Nvidia Green Fans
- Power Supply: Corsair TX 750W ATX Modular SLI Compliant Power Supply
- CPU: Intel Core i7 930 2.80GHz Overclocked to 4.00GHz
- Motherboard: Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: Prolimatech Megahalems Rev B CPU Cooler with 2000RPM Sharkoon Silent Eagle 120mm
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Low Latency Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: OcUK Value GeForce GTX 480 1536MB GDDR5
- Sound : 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive - Black
- Case: Antec Dark Fleet DF85 Gaming Case - Black
- Power Supply: Corsair Extreme 600W
- CPU: AMD Phenom II X6 Six Core 1090T Black Edition 3.20Ghz overclocked to 4.00Ghz
- Motherboard: Asus Crosshair IV Formula 890FX
- Cooler: Corsair H50 CPU Cooler (H70 option available)
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
- Hard Drive: Seagate Barracuda 500GB 16MB Cache
- Graphics Card: Choice of the latest DX11 graphics cards
- Sound: 7.1 Channel Sound (On-Board)
- Case: Lancool Dragon-Lord PC-K62 Mid Tower - Red Dragon Windowed Edition
- CPU: Intel Core i7 930 2.80GHz overclocked to 4.20GHz
- Motherboard: Asus Rampage Extreme II (Socket 1366) DDR3 Motherboard
- Cooler: Prolimatech Megahalems CPU Cooler w/ Sharkoon Silent Eagle 2000RPM 120mm Fan
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Choice of the latest graphic cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: 22x DVD+RW SATA Dual Layer ReWriter
Thanks in advance :)
If you want to add another 480 GTX then you need to look at the Intel systems as the AMD can only do Crossfire, also you would need to upgrade the PSU on both machines.
Between the two Intel machines I probably father the first one.
So is it worth switching out the gtx480 in the amd option for the equivalent ati card?
The closest would be the 5870 which you can go crossfire, AMD (ATI) are due to launched there new range other the coming months.
Ok I will consider that, but at this stage if I were to keep the single 480 in all of the systems would you still favour the first?
