ANT Renamer
Right, the way I ahve found to do it is just by searching the folder where the files I want, reside for ".mp3" and then adding them into Ant Renamer but the issue is that when I press go, it does add the 0 on for ones that need it but also, if the current filename is over 8 characters, it will just cut it off. How can I fix this?
