Antec 100 question
31 Oct 2002
Trying to choose between a few cheap cases, just wondering if the Antec 100 has the same removable dust filter in the front as the 200 and 300? Thanks!
The 100 has no dust filter.
Antec say that the perforated front bezel is the washable filter.
Seeing that it is just the front of the case full of holes then dust will get in.
Also you cannot fit a dust filter anywhere.
Surely a sheet of fine wire mesh or some tights stretched out over the front ant stuck down with duck tape will do the job? (obviously hidden behind the front bezel...)
