Antec 1200 Dust Question..
4 Aug 2004
on OCUK
Hey people!
Im guessing a lot of peeps have this case as its awesome :D ?
However the dust that gatherers at the front of the case (the 3 fans) do any of you guys know any better way to clean them apart from taking the case apart and taking out the filter hoovering then back again..it can be time consuming :( It could be cleaned quite easily from the front if it wasnt for the grill!
Any recommendations?
Thanks
Well, I just see it as a regular thing. Opening the side panel is easy with the thumbscrews, then popping the fans out as they're not actually screwed down to anything. I remove the filters, wash then blowdry them, then I get a hoover and suck out the dust that accumulates inside the case, then a good blow over with the vacuum :)
Of course, this may not be pratical for everyone to do :P But that's just an idea for ya
Well tbh I don't measure my temps at all, I just look at the front of the grill and if dust is caked in it which takes about 2-3 weeks to do so, I clean it out.
