Hi all, i cant get my earphones to work on this case, there is no holes in the back to plug them into, there is 2 holes on the front though, i tried them aswell with no luck, please help
There should be an ac97 (audio) cable wired to the sound ports on the front of the case (along with a usb cable). This can be plugged into your soundcard or motherboard.
