Hi! I'm a long time forum lurker after a bit of advice if possible. With haswell coming up and the recent purchase of a HIS 7970 (on RMA
), I plan on giving my case a good clean out when I upgrade as it's gotten a little dusty inside. As well as that, I was wondering how I could soundproof it.
I realise soundproofing something with so much mesh is difficult, so far my plan is to replace all the stock fans with silent ones and put rubber grommets on all the screws. Also, my PC is between my desk and a corner wall, so I was considering lining the 3 sides with foam. Is there much I can do beyond that?
I've also noticed that the dust filters on the front aren't overly effective, even when kept clean (which is a hassle on the 1200), are there any better materials or methods out there which may help?
Many thanks.
), I plan on giving my case a good clean out when I upgrade as it's gotten a little dusty inside. As well as that, I was wondering how I could soundproof it.I realise soundproofing something with so much mesh is difficult, so far my plan is to replace all the stock fans with silent ones and put rubber grommets on all the screws. Also, my PC is between my desk and a corner wall, so I was considering lining the 3 sides with foam. Is there much I can do beyond that?
Many thanks.
