antec 1200
28 May 2007
Saturn’s moon Titan
hi peeps has anyone got this case my wee hard drive light(the blue led has a mind of its own sometimes it stays on constant. and the only way to get it to stop is if i shut down the pc and power it up again has anyone of you had this wee problem?
regards scubes...
i wouldnt worry about it, mine hasnt come on since i rebuilt the computer
regards scubes...
I have no problems with my hdd light but if it you want turn it off due your problem just pull out the HDD wire near the pwr/sw/reset that plugs into your mobo wont effect the drive at all
