Antec 1220 No CPU temp
7 Jan 2009
Hi guys,
Just fitted an Antec 1220 to my i5 4670K and having problems.
I have connected the 3 pin wire to the cpu fan header and the usb header and after some software issues I have control over the fans with the chill software app supplied. The app does not show CPU temp and the fans/pump do not change speed with load so far playing BF4 or Titanfall. Temps seem ok though.
There is another lead which joins the two fans supplied to allow 2 more and I have tried that on a fan header too.
I have built before but never watercooled and am concerned. Can anyone help please.
Cheers
Dave
Have you downloaded the latest software from Antec's website?
I've never used one of those coolers so can't really comment on it, but I always get my temperature reading from HWMonitor.
Yep I have that ok. All working and I can speed up or slow down the fans there. I have downloaded a temp program and that shows the core temps ok.
Not sure if it is a wiring or software issue.
