- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi all
I'm working on a project using the Antec 1900 Case.
MSI red Z87 Board
Bitspower red CPU waterblock, fittings and pump cover.
TeamSpeed RED 1866mhz RAM.
The rest is to be confirmed.
Here is the case in naked form.
First thing I had done is get the large side panels and the top sprayed in red.
That was a few months back. More recently I decided that I wanted to remove the HDD cages and 5.25" from the main section. I drilled out the rivets and now I ahve something like this...
Poor 5.25" cage died in the process.
And so did the HDD cage too.
MSI red Z87 Board
