Antec 300 Cable Management
26 Dec 2008
Cornwall
Hey OcUKers,
I recently purchased a new HSF from the members market, now if I wish to fit it I have to take my entire mobo out my case, so I've felt as I will have the time I thought it'd be good to do some cable management inside the case, as it currently isn't exactly managed.
Here's what it currently looks like -
Any tips on the best way of managing the masses of cables?
get 8 pin extension and tuck it in the corner with those 1-4 rpm changers, also put most of the cables through to that big gap in the back, i bought this case couple weeks ago, and mine was pretty half decent. Il take couple pics 2morw.
i replaced my antec 300 with the 690 II becuase of the lack of cable management :(
Im thinking about buying this case, is the cable management-ability to a fairly high standard? Also what are the differences between the 'Lite' and the 'Advanced' model of this case?
you can indeed have tidy cables in a 300 :)
lots of work though :)
and how it ended up :)
their right buy a different case the 300's hardwork
Best of luck. Doesn't seem a well designed case at all. One of my main reasons for moving from Antec.
well lots of sweary words later its looking a wee bit tidier
how we started this evening
some pics of the semi tidy 300 :)
me thinks it will be a new case along with my bulldozer/ivybridge rebuild come year end
A 25mm holesaw + cable grommmets =
Sorry for the poor pics, and excuse the dust! :o
Can of compressed air required!
