- 16 Jul 2010
- London
I have tried various fans with little joy when gaming or folding things are not as it seems whilst ultimately like to add a 2nd graphics card which i fear make cooling problems worse.
Currently Antec 300 case with i5 2500k, EVGA GTX 570 SC with 2x Corsair 120mm fans in the front and Antec tri cool 140mm fan at the top.
The obvious problem apart from heat is the air flow seems to stall when gpu fan goes over 50% much less air can be felt out the top 140mm fan and the 2x corsair 120mm whirring away flat out temps reach upto 80oc for both gpu and cpu. The open vents are sucking air in, i tried blanking these off and both gpu and cpu temps increased approx 10oc
Without folding stressing the cpu alone it hovers around 50-60oc max and uncovered vents are blowing air out; so i guess gpu is sucking more air than both 120mm fans can supply at full speed not to mention uncomfortably loud.
How should i set up the fans and recommend better 120mm fan than Corsair because i hope to go SLI with another GTX 570 SC.
