As it's £39.98 at the moment I thought I might buy one.
One question though, it says:
This means that the two TriCool ones come with it, and the other three are not included correct? Or does it mean you can remove them?
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
