Hi,
Just put my old system together in my new case, an Antec 300. It's a great case and the build went smoothly, but some fan in my system is spinning up a lot, which never happened at all in the old case.
It can't be chipset since that's passively cooled, it can't be my VF900 since that's on a fanmate, it can't be the case fans since they're all either on a fan controller or have 3 way switches. So that leaves CPU and PSU. CPU temps look exceedingly good (with AC Freezer Pro), like 19/23 at idle (reported by coretemp) and nothing worrying under load, so I'm thinking it's my Corsair HX520.
With the bottom mounted PSU there's very little space under the PSU for air to get into it's intake, less than a centimetre. Anyone else had similar problems with the PSU location in this case? I suppose I could mount the PSU upside down maybe, but that might not be good for it, and my soundcard will block the air nearly as badly.
Btw the bottom fan cage on the front is currently empty, as is the side panel fan mounting. So I currently have 12cm exhaust, 14cm exhaust and single 12cm intake, which could be sucking air away from the PSU intake. I will be fitting another 12cm intake on the front in the future.
Cheers for any guidance,
Simon.
Simon.
