- 10 Sep 2006
- UK
Is it OK if I mount my TX650W with the fan facing down?, or should I flip it over so the fan is facing up?, the reason why I'm sure if it matters or not in because there is a little clearance where the fan can draw air in even if its mounted with the fan facing down, and the top of my PSU is quite cold to the touch while in operation. So does it really matter?
Another reason why I haven't bothered is because I have a 120mm fan on the side fan slot which would be incredibly close to the PSU fan if it was mounted facing up, so wouldnt this disrupt airflow? as (I think...) the air blown into the case from the side fan would be (while facing up) immediately sucked in by the PSU fan?
Thanks.
Thanks.
