antec 300
It fits my 2900XT with about 1cm to spare. Check the dimension difference between the two cards.
EDIT:
hrm...
2900XT = 220 mm
GTX280 = 266.7 mm
Looks like you might be out of luck.
the GTX260 fits in my antec 300..
the GTX260 and the GTX280 are exactly the same size.
it is a squeeze, but it fits pretty nicely
My 8800gts 512 fits, but there is really not much room between the end of the card and the hard drives, making getting cables to the hard drive directly next to it, and the 6pin power a huge PITA, especially with thick braided cables:p
