Antec 4 pin extension
19 Oct 2002
Hi gang,
Got this extension cable and it has 2 4 pin and 1 8 pin
How do I connect this up?
Do I just stick the 4pin in the mobo and the 4pin of the psu in the bit market cpu1 on the extension cable?
It'll kinda look like
[4pin]-----------------------------------------------[8pin]-------------[4pin]
Left side 4 pin into the power supply, and either the right 4 pin or right 8 pin into the motherboard depending on how many pins are required for your mobo's 12v connection.
Hi, would I be right in assuming that this would work on an AMD system with 1 4 pin plug, just plug the 2 4 pins on the PSU end into the extension lead, then just plug CPU1 connector into the 12v on the mobo???
I want to know cause I want to get one for my P182, so I can run the one CPU cable behind the case instead of running it through the case. Thanks in advance.
Anthony
