Antec 620 / 920
22 Dec 2002
Minehead
I'm looking for some advice regarding the all in one cooling solutions above. Will the 620 be adequate for an i5 760 clocked at 4Ghz, or would I be better off getting the 920? The 620 comes in at £34.79 and the 920 at £61.19. Is the 920 worth the extra cost?
Can any of you comment on the quality of either product if you should have them? Many thanks!
