Antec 620w PSU enough for 970sli?
Unfortunately, that link is 404-compliant.
But 620W should be more than enough. Had Nvidia released 8 GB versions - or even 7 + 1 GB versions :D - I would now be running two 970s off a 460W PSU - granted I use a 65W CPU.
100w minimum for your cpu, around 400w for sli 970's with no overclocks.
Yes, the psu will more than likely cope - but for how long?
Would I risk it - hell no
Thanks for the advice guys, I am not sure whats up with the link, it works for me :(
The PSU is an Antec and has the product code HCG-620 (not the M)
My one has 2 x 6+2PCI-E, would it be ok to use an 8pin in each card and a molex to 6 pin connector in each? I know the 970 don't draw massive amounts of power and I'm thinking that I might be able to get away with it!
