Antec 900 card space question
11 Jun 2003
Sheffield, UK
Can probably answer this soon enough myself but:
Can the antec 900 take a GTX/3870X2 sized card?
From the look of it, should probably go?
As a seperate question:
Whats the best 120mm fans to replace the defaults with? My housemate has a '900 and its not the quietest.
You would have to take off the fan bit in the inside of the HD rack (the black plastic bit where you can attach another fan if needs be).. sorry that doesnt make much sence,
Exactly, just take the back bracket thing off the middle pull-out bay, and yer 8800GTX goes in a treat.
As for the fans, the defaults are pretty quiet considering the amount of air the shift, you certainly can't hear the actual motors, so I doubt you can get MUCH quieter.
What you can do is set them to medium or low, they still provide amazing airflow, and are almost inaudible. You can always use a fan controller. That was my solution.
set fan to low and u cant hear them set to medium it gets litle noisy... set to high and u have a jet in ** room x]
