Antec 900 fans speed control?
21 Oct 2002
Bexhill on sea
A friend of mine has bought one of the "ultima" systems off ocuk using the antec 900 case and while the system as a whole goes like the clappers, its a bit noisy due to the fans appearing to be running flat out.I've read in the specs for this case that the fans each come with a speed control to slow them down. Could anyone here let me know where they are pleae so I can pass this info on to him?
Thanks.
Its a small white cable next to the fan with a 3position switch. Low - Med - High.
You will need to take the side of the case off.
Black cables on mine. Closest position to the cable is "Low".
Black plastic cables on mine also, look a bit like cable ties.
I have all mine on High, when you have a 120mm Delta in the case also the extra noise from the case fans is negligible :p
