I have just bought an Antec 900 second hand and unfortunately it is missing 2 of the front mesh bits. I have sent the seller an email as I want to run the PC with any optical drives.
If the seller has lost them does anyone know if you can buy them from Antec?
Would using these Lian Li bits work or would they just look a bit odd
http://www.overclockers.co.uk/showproduct.php?prodid=CA-241-LL&groupid=701&catid=7&subcat=
Failing that does anyone who has an Antec 900 or 902 or maybe even 300 have any spare ones knocking around?
Cheers all I hope I can get this case looking sexy again
