Antec 900 & hdds in the fan cages
  • Thread starter Thread starter urx
  • Start date Start date
urx
urx
14 Apr 2006
I got a 900 the other day without any of the screws that normally come with it. I'm looking at mounting hdds in the 5.5" fan cages that take up 3slots each in the fron of the case.
I havent figured out where to get suitable screws from though as they look like I'll need em about a mile long and very thin to mount through the cages and reach the 3.5" drives :confused: or am I missing something really easy here?
You remove the cages from the case and the screws themselves are standard 6-32UNC screws that come with every case. Email / phone Antec telling them you didnt get screws. I assume you have a few spares as you need risers too.
I have a small crate of adds n ends left over from system builds over the years. None of the usual screws seemed to fit the holes :confused:
I'll have another look tonight and see
I just got a 1200 from OCUK and it also didn't come with the box of screws, I phoned OCUK up and they found me a box and sent it out straight away.
Give them a bell and they can probably get some out to you.
