Antec 900/p180 side panel
21 Jun 2007
Does any body know if i would be able to replace my antec 900s windowed panel with a p180 side panel ?
If not does any one know of a plain side panel which will fit the antec 900?
I don't think the Antec P180/P182 side panel will fit an Antec 900, but not 100%. You can buy Antec 900 side panels that are solid and plain but you will have to search for that as we can't give links.
What is the other side of the 900 like? Is it plain? If so you might be able to switch the panels over and have the currently left side on the right and vice versa.
