Antec 900 side panel = 902 Side panel?
15 Jun 2009
Edit: Found out that it isn't the same. The 902 has a little angled bit at the front right, Meaning the two sides aren't interchangeable. Ruins my fun.
Just wanting confirmation here that both side panels are practically the same for these two cases?
Looking to buy the Right panel, Which Antec only sell in the 900 variety, and then mod a completely custom window into it, Which means I dont have to create a window that is bigger than the standard one.
you should be able ot buy them seperate, i bought right hand for my 900 as i didnt want any window, still got the old left panel with window doing nothing!
i think but cant actually remember i got mine from antec...but i could be wrong!!
