Hi all
I've got an Antec 900 case, which i previously bought from OCUK and am wanting to replace the stock fans it came with.
Problem is the bottom front fan doesn't seem to work anymore, i've fiddle with the connection etc but it doesn't wanna spin, so i guess i need some new ones and the other front fan isn't performing too well, think it's dying too.
The back exhaust fan which is the same performs great, maybe i'm just noticing it more now the front pair are wearing out. Also wanting to get another 120mm fan for on the side of case, parallel to my hd4870 card which could do with some extra cooling.
Any ideas on what're the best 120mm fans to use? I'm online a lot during the night so don't want them too noisey, not sure what these stock fans produce in DB but anything around that or slightly higher is fine (i run them on max btw).
Price isn't too much of an issue either and LED's doesn't bother me much, pref in black though to match case or similar.
Heard a lot of people recommending Noctua & Delta? Any ideas? Am also considering just replacing them with the same type which is these (i think) Antec Tricool(s)
Cheers lads
Edit: Changed link due to request, i think this one is the same though the one i had originally linked stated:
# Rotation Speed: 1200/1600/2000 rpm
# Air Flow: 39/56/79 cfm
# Noise Level: 30 dBA
Antec site states:
# Fan Speed 1,600 RPM (avg.)
# Volumetric Airflow 56 CFM
# Acoustic Noise 28 dBA (at average rpm)
Guess they mean on medium settings.
Cheers lads
Antec site states:
