Antec 900 Upgrade
21 Sep 2008
Need to upgrade as my Antec 900 is running out of space, very cramped inside with wires everywhere. Also not keen on the amount of dust it has collected :p
Have been looking at these so far.
Antec 1200 - Direct upgrade to space, and dust managment, cable managment.
HAF 932 - Doesnt look like Antec 900 so something new to look at, looks nice inside for wirering and adding more stuff. Airflow looks good, with those 3 huge fans.
Budget is around £100-£150, mabe higher if anything else stands out.
P182 just looks to plain, and i have never liked the look of the Lain Li range :(
Seen some really nice pics of the HAF in built systems, this case seems to be in the lead for me atm, unless someone can sujest something better :)
Code:
.		W(mm)	H(mm)	D(mm)
A900		206	493	467
HAF 932		229	546	576
A1200		213	582	513
GS1000		220	560	580
LL A PC-P60B	210	545	540
Some of my research into size if it helps anyone.
Leaning towards the HAF atm, cause its price seems stupidly low compared to its competiters and has very little going against it.
